Here is a page from the installation instructions.Update: I found the leak. It's on the back side of 060 in this diagram:
It's probably one of the 0-rings (070) which I plan to order.
BUT - - in the meantime,
Does anyone know the torque specs of the 12mm bolts that hold the block on (seen below) ?
Those would be 4 12mm bolts that hold on the distribution block (1st diagram) or a cap if no loader is installed (2nd diagram).
I am currently at 23 ft/lb and they're still spinning, but I don't want to push it and strip them.
Thanks in advance.
