Hello All, I’m a BX owner wanting to get larger tractor for brush hogging and grapple work. I’ve been eyeballing the LX310 and through my googling I came across a thread here where a member stated the LX3310 would be limited to a bush hog that weighed 500 lbs or less due to then3 point construction of the LX. This appears to be true as Landpride only recommends 48” hogs and I believe a light duty 60” for the LX33.
I would definitely appreciate some help with being able to determine how to interpret the 3 point capacity figures, as when the numbers of the LX33 and L33 are compared, they are incredibly close. Same with PTO hp ratings between the two. On paper the two tractors have nearly identical rated capacities and hp, but all of the heavier rotary cutters listed on Landpride are recommended for L series or larger tractors.
The LX3310 meets all of my needs except I would like to be able to run at least a 60” medium duty cutter. I just don’t want to buy a tractor that isn’t much more capable than my current BX.
