Hello All,
This is my first post so hopefully this is the right place to ask. I have a new to me L3750 4wd. I am trying to replace the rear axle seals. They are leaking hydraulic/transmission fluid when it is sitting.
To remove the rear axle shafts do you just pull the axle cover (I.e. cover with 4 bolts and the seal) and hammer the axle out? Or do you have to pull the gear case and undo a axle clip or re
