Just got word from my dealer a second switch needs to be added. When they do that next week I will update
So I got curious and took a look at my L3901 and that seat has a similar switch to the OP. Then I noticed that there isnt a switch for seat up (that I could find). I've been running a logging winch off the back with the seat up and the PTO running (I have to stand off to the side of the winch and I am definitely out of the seat). But I can't figure out how the PTO runs with the seat up. So, Im in the same boat as the OP now on my other machine. Going to read the manual and see if I can find something new to learn.Just got word from my dealer a second switch needs to be added. When they do that next week I will update
The switch on the L01's has three positions. Down when you are in the seat, middle when you aren't in the seat and up when the seat is flipped up.So I got curious and took a look at my L3901 and that seat has a similar switch to the OP. Then I noticed that there isnt a switch for seat up (that I could find). I've been running a logging winch off the back with the seat up and the PTO running (I have to stand off to the side of the winch and I am definitely out of the seat). But I can't figure out how the PTO runs with the seat up. So, Im in the same boat as the OP now on my other machine. Going to read the manual and see if I can find something new to learn.
Thanks,The switch on the L01's has three positions. Down when you are in the seat, middle when you aren't in the seat and up when the seat is flipped up.
Helpful! Thank you.The switch on the L01's has three positions. Down when you are in the seat, middle when you aren't in the seat and up when the seat is flipped up.
Does your switch and trigger point look like this? Don't think this will work with mine.So I got curious and took a look at my L3901 and that seat has a similar switch to the OP. Then I noticed that there isnt a switch for seat up (that I could find). I've been running a logging winch off the back with the seat up and the PTO running (I have to stand off to the side of the winch and I am definitely out of the seat). But I can't figure out how the PTO runs with the seat up. So, Im in the same boat as the OP now on my other machine. Going to read the manual and see if I can find something new to learn.
