The KH41 has a timer relay that the light comes on when keyturmed to glow plug position andwhenthe light times out you go to crank and away she goes. Would a 15amp rated switch now work without a relay??
Your problem should be fairly straight forward, assuming
1. The diagram in the WSM is correct and
2. I'm correct in assuming that you turn the key switch backwards (counterclockwise) to preheat.
The preheat light is advisory only - the timer only actuates the light and doesn't control the glow plugs. Here's what I'd do:
1. Remove the small wire (or the big one) from the starter solenoid so the machine won't start.
2. With the switch off, use a tester or light to find the battery connection on the switch. Probably a heavy red wire. No other terminals should show voltage.
3. With the key turned back to the left, one terminal (besides the battery connection) should show 12 volts. If not, the switch must be bad. Is so, there must be a bad wire or connection between there and the glow plugs. Trace that wire to the glow plugs until you find the break. (Or run a new wire) There should to be 2 connectors between the switch and gp's, but no relay.
I'm betting it's the keyswitch. If that contact is bad, the glow plugs won't work and the light won't come on (you have tested the bulb, haven't you?).
