Do I dare ask something else? Well, why not. Here's the deal.
I made a BIG mistake. I built a "holder" for this 60" deck because it is just far too heavy to manage. I used the furniture dollies from HF as one of the other forum members did a couple of years ago. Worked great...got the
mower onto the dollies, wheeled it around, etc. It sat solidly and was easy to maneuver.
I wanted to sharpen the blades but after I got the mower vertical, it seemed to me that a better choice would be to buy new blades...but that takes time to get them. I sharpened the existing ones a bit and figured I could use it
until new ones arrived. All good so far.
Now, I had to use the loader to lower the mower back to horizontal. Chain was in place, all going as planned, when I noticed that I had the chain hooks heading the wrong direction. If I lowered the loader to release the tension on the chain, the mower would certainly fall. So, I lowered the mower just enough to rest it back on the dollies. As I got off the tractor, I put it in neutral which is what I always do. However, in neutral, the tractor began drifting backward and I didn't have time to react. The loader was low enough to push the mower at the top and down if went with a bang, upside down onto the concrete floor!
At that point, nothing seemed harmed other than my nerves...and confidence. I got the mower back righted again and back, ready to mount on the tractor. Again, no problem. I pushed it under the tractor and left it.
By the next morning, I could see that oil had collected below the gear box onto the top of the mower...maybe 1/4 cup of oil or so. I had my dreads but hooked the mower back up (after I had solved the fuel leak problem) and went out to mow a bit. Prior to running it, I wiped any oil off the deck so I could see if there was more oil to come. ...and there was.
I mowed one round and came back into the garage. Now there is more oil but it is darker. I have not removed the deck yet to inspect more closely but with a flashlight on the gear box all the way around, I do not see any cracks, damage, or oil. The oil seems to be coming from under the gear box.
The diagram on Messick's for this mower shows an oil seal. Is it possible that only this seal has been damaged? Or, would that kind of a clunk cause other problems when it fell? I noticed that the blade speed was not enough to fully cut the grass in the way it had done before. Doesn't seem like an oil seal problem would cause that.
So, if anyone is willing to offer an opinion, I would be most grateful. I'm not sure how hard it would be to remove that gearbox and/or pulley to get to that seal, especially with the weight of this mower. I don't have a lot of work area but I suppose I could lift the mower with the loader and get it up on something.
Thanks again for any help/advise. My biggest concern is that I have really damaged something more than the seal. So, I could take this to the dealer or maybe find someone to repair any damage or change the seal since I could lift it with the loader into a pick up bed.
Tractor Gal
Tractor Gal
