STARTING LX 2610
Orange man hero
LX2610HSD
Mar 12, 2021
343
42
Wasilla, Alaska
Mine is pretty new 35 hours. It has been around 45-55 degrees. I do the glow plug for about 10 seconds and it won't quite start. After the firing of the cylinders and the heat that creates, it usually will start, many times on the 3rd try after waiting each time for the heat from the firing to heat up the cylinders. IS this common at such temps? Do I just need to do the glow plugs longer?
FarmerJohn
LX2610SUHSD
Jan 25, 2021
25
NC
I’ve started mine (SU) in colder temps with less or no glow plug without issue. Seems like something is amiss.
Njtool
Lx2610 HSDC. BH77 backhoe
Jan 1, 2021
216
281
New jersey
You could have burned out the glow plugs. I believe even the manual says to heat them for 3 seconds if the temp is above freezing, and 5 seconds if it’s below freezing
je1279
Dec 6, 2020
828
581
Upstate NY
You shouldn't need the glow plugs for more than 2-3 seconds at those temps. I would call the dealer and notify them of the situation. How long are you cranking it for, what are your night time lows and are you using an anti-gel in your fuel?
Orange man hero
LX2610HSD
Mar 12, 2021
343
42
Wasilla, Alaska
Not using anti-gel...when it was colder like 20/30 f I used the block heater and it started pronto...
Orange man hero
LX2610HSD
Mar 12, 2021
343
42
Wasilla, Alaska
I don't crank it but for the few seconds it does not light off.
Freeheeler
b2650 tlb
Aug 16, 2018
706
525
Knoxville, TN
Mine starts with just a bump of the key, no glow plug use unless it's 32 or less. I would assume there is something not quite right with yours. I would visually check the fuel and filters, and make sure the battery is fully charged. Good luck, hope it's something simple to fix.
Njtool
Jan 1, 2021
216
281
New jersey
Same here. I lite the glow plugs for 1-2 seconds and she usually fires up on the first compression stroke
nbryan
Jan 3, 2019
1,309
831
Hadashville, Manitoba, Canada
Do you bump up the throttle a bit before starting?
I set my idle before shutting down to between 1250-1300 rpm where it is set when I start it up again.
And 5 seconds is glow is plenty in above freezing temps.
Orange man hero
LX2610HSD
Mar 12, 2021
343
42
Wasilla, Alaska
No , mine is set at lowest idle and I bet you are right. Thanks
sardillim
b2650
Nov 24, 2019
126
62
Easton
I have a LX3310 Mine was also a little stubborn starting when cold. try holding the key until the glow plug light turns off on its own. My machine has about 45 hrs on it and it seems to cold start faster now vs when it was new
B2710
LX3310, L45, RTV1100
Dec 13, 2011
42
26
SE Tennessee
LX3310 have auto preheat, I am positive the LX2610 does not, you have to time it by holding the key the appropriate time.
Snowman7
May 20, 2020
390
284
Boyne Falls, MI.
My new 3310 took a few try’s, it runs for a second and dies. After the third try she runs
troverman
Jun 9, 2015
1,178
264
NH
Something sounds off. My last tractor without auto preheat was a 2019 L2501, which had the 1.7L direct-injected (mechanical) 3-cylinder engine. I live in a cold environment and it was one of the best starting tractors I had. The LX2610 should start very quickly. I'd make a video, then get the dealer involved.
