Land Pride third function valve
Geezer3d
Kubota LX2610SU
Apr 22, 2021
222
222
Heart of the Catskills
I have a LX2610 with a Land Pride third function valve. It works great with the Land Pride grapple and I am very happy with the function. However; when I have the bucket on the loader and nothing is connected to the third function valve I find myself pushing the buttons accidentally while operating the bucket. Has anyone solved this problem or do I simply have to learn to keep my hand and fingers away from those buttons?
5,268
Some I’ve seen seem to have an on/off as well as a open/close. If you have a on/off, I suppose you could turn it off. Mine doesn’t have the on/off, just the open/close toggle. I change my grip when not running the grapple and keep my thumb off the toggle. Basically leave my hand in the same place but let my thumb float rather than gripping with thumb. Stick is pretty easy to move so don’t need a death grip on it.
Don’t know that it would cause damage to bump it once in a while, but charging disconnected lines just doesn’t seem to be useful and generally less than ideal so I don’t do it.
Geezer3d
Kubota LX2610SU
Apr 22, 2021
222
222
Thank you for the reply. My third function valve does not have an on/off switch. I have seen that in some you tube videos and I assume they have another make of valve. I will try to change my grip so I don't push the buttons. My buttons are on the outside of the knob, opposite my thumb.
bird dogger
Vendor Member
Feb 24, 2019
1,720
1,670
North Dakota
I added a separate "ON/OFF" toggle switch to my 3rd function install so that it can be de-energized when the grapple is off or not in use.
Njtool
Lx2610 HSDC. BH77 backhoe
Jan 1, 2021
216
282
New jersey
I have a 2610 with a kubota 3rd function. There is an on/off button on the outside of the stick a little lower down. And the operator buttons are on the inside of the stick.
I can post pics later. But I’m curious of your setup. Can you post pics?
wgator
L4701HST, FEL and other stuff.
Jul 28, 2018
482
147
NC
Below attachment is from land pride install instructions. As shown in attachment, loosen jam nuts and the set screws, turn the knob until you get buttons where you want them, then tighten set screws and jam nuts.
Geezer3d
Kubota LX2610SU
Apr 22, 2021
222
222
I was wondering if that could be done. That way, with the buttons on the inside by my thumb I may be less likely to push them unintentionally. I will try that.
Geezer3d
Kubota LX2610SU
Apr 22, 2021
222
222
That is a good idea. Did you access the wiring where the fuse is? I am hesitant to cut wires right now because the tractor and implements are still shiny new.
Geezer3d
Kubota LX2610SU
Apr 22, 2021
222
222
5,268
Yeah, I would not like it at all if the button wasn’t on the inside where it naturally falls under my thumb.
Geezer3d
Kubota LX2610SU
Apr 22, 2021
222
222
I will spin it around tomorrow. I think that will put the buttons in a better place where I am less likely to push them unintentionally, and having them on the thumb side will be extra insurance against pushing both at the same time.
Njtool
Jan 1, 2021
216
282
New jersey
Where is the control valve at? Is it protected or is it out in the open?
bird dogger
Vendor Member
Feb 24, 2019
1,720
1,670
North Dakota
Yes, on my B2650 at the fuse box I found a 12 volt supply that was switched "on" with the tractor's key. I tapped onto that wire to feed the ON/OFF switch I added for my 3rd function control.
Njtool
Jan 1, 2021
216
282
New jersey
Here is the control that’s on my 3rd function. The green light lights up when it’s on. Sometimes I hit the “on” button with my hand and I don’t see it’s on because it’s hidden from view when I’m in the seat.
Geezer3d
Kubota LX2610SU
Apr 22, 2021
222
222
The control valve, the part with the two solenoids, is in front of the brake pedal and protected from the side by a heavy steel plate that goes up to where the loader is mounted. That looks good to me.
Geezer3d
Kubota LX2610SU
Apr 22, 2021
222
222
I had the same problem so I installed a switch. When the switch is on it lights up.
That looks like a good solution. I have rotated the handle around so the buttons are on the thumb side and that looks like it will work for me. If I still have trouble with it then I will go with the toggle switch that lights when on. Thank you.
Geezer3d
Kubota LX2610SU
Apr 22, 2021
222
222
Thank you all for your help. I think I have a reasonable solution now by rotating the control handle so the switches are on the inside, by my thumb. I am surprised that the installer didn't do it that way in the first place, but that's the way things go.
