A friends new BX2380, No clutch pedal and the motor is in backwards
cmorningstar01
B7500HST LA302 FEL 5'Finish Mower B5100E 46" Snow Plow 22 ton splitter
Mar 27, 2011
341
81
Pemberton NJ USA
A friend just purchased a new BX2380 with the LA344 loader, While looking it over today I noticed there was no clutch pedal and then I realized the motor was facing with the water pump rearward and starter flywheel on the front, Looking closer I could see an Oldham style coupling on the crankshaft that connected the engine with the transmission.
The radiator was behind the motor in a nice safe place...I was impressed.
Sure was a lot different than my B5100 and B7500 machines
i7win7
Feb 21, 2020
3,377
3,992
Central, IL
Watch this video on after market cab and you will think all small tractors should have a reversed airflow
mcfarmall
Kubota M5660SUHD, Farmall C
Sep 11, 2013
1,445
1,742
Kalamazoo, MI
The 88 series International Harvester tractors had "Forward Air Flow" The engine was mounted traditionally but there was a hole in the radiator where the fan shaft went through with the fan mounted in front. The air intake was through a screen on the top of the hood.
dlsmith
BX2230, LA211
Nov 15, 2018
1,331
978
Goshen, IN
When we had a couple of IH dozers many years ago, both the TD20 and the TD 15 had reversible fans. With the engine stopped, important part of the process, you could push the spring loaded fan blades in on the hub, and rotate them about 45° to switch from a pull fan for the winter, to a push fan for the summer. As long as you kept the hub greased, it worked really well.
5,163
Mr. Ritter has made a lot of videos, and I wonder if he is really buying the items that he is featuring, or if they are being supplied to him by the manufacturer. If they are being supplied by the manufacturers, then I believe that he should disclose this in his narrative, or in the credits at the end of the video.
i7win7
Feb 21, 2020
3,377
3,992
Central, IL
Auburn, Cord, Duesenburg made cars with the entire drivetrain reversed producing front wheel drive cars. All Duesenburgs were test driven at 100mph before shipping.
JohnDB
M4500DT with FEL, back blade, Someca K28 hay mower, drag broom, post driver
Jun 9, 2018
531
155
NZ
Probably built on a Monday or a Friday.
