Recently I added rear remotes using the Kubota kits and the PB of that Kubota valve stack is what feeds the Backhoe itself. I’ve been pretty OCD when it comes to securing the 3-point hitch lever in the down position when hooking up the backhoe for use. In this snip from the BH77 manual, it’s also advising caution about downstream remote valves, but I would think the BH itself would be downstream of the rear remotes (at least from Kubota, anyway). Is that how others would read this? There’s no question my BH gets flow into it from my rear remotes, and the outlet flow of the BH then heads back to the tractor’s hydraulic block at that PB port. Opinions welcomed.
