Pulling teeth
Crash277
BX23S
Jan 17, 2021
844
623
I have some ditch work to do, anyone just pull the teeth off their backhoe bucket to avoid teeth marks where they are digging? I did a bunch of it already but I’d like it a bit smoother.
BAP
Dec 31, 2012
3,177
1,295
You will wear down the teeth mounting spots, then your teeth won’t fit tight anymore and will be harder to keep them on. Better off to make a plate that mounts over your teeth if you want a flat surface.
Crash277
BX23S
Jan 17, 2021
844
623
that was my exact worry. I did debate on making a bolt on edge that was 16” Wide
pokey1416
Jun 24, 2020
572
885
SW Michigan
There’s a thread out here somewhere on this. I think the official name for the bar you’ll be looking for is a “crumbing bar”.
MOOTS
MX6000
Jun 27, 2019
2,232
2,850
Canton, Georgia
3,535
I bought another bucket & cut the teeth off of it.
It has been very handy, like this:
3,396
I often tilt my bucket so the teeth are pointing up slightly, than drag it along the bottom to smooth things pretty well...This requires coordination between stick and boom movements, but is not too difficult to get fairly good results.
Just offering a possible work around...
kubotafreak
Sep 20, 2018
1,049
402
Arkansas, US
Since you obviously have the bolt on vs weld on teeth, could you just buy a small piece of cutting edge and drill some holes to match? Seems easier than fabbing up a piece of random grade steel. I bet you can buy the width you need too without the need to cut it.
Crash277
BX23S
Jan 17, 2021
844
623
if i make my own plate for it, it wont be a random grade steel. I got a good friend who works with steel for a living, anything heavy duty he helps me build.
