Leaky front rear
Ktrim
Dec 23, 2020
425
337
Nazareth Pa
Having an issue with b2400 front rear leaking bad at the swivel joint. Changed the seal about 2 months ago and is leaking bad again. Any ideas????
foobert
BX2380
Mar 25, 2021
112
111
Washington
:unsure: what's a "front rear"?
I can't get past the oxymoron of it😁, but, maybe you mean the driveshaft seal on the front axle?
foobert
BX2380
Mar 25, 2021
112
111
Washington
I'd be looking at the run-out on the shaft with a dial indicator. If the shaft is bent or the bearings are shot, the seal is doomed to keep failing.
Ktrim
Dec 23, 2020
425
337
Nazareth Pa
Good place to start. Thanks
