Was using my box scraper yesterday to level ground that had just been cleared. Noticed my BB was not sitting flat to ground. Checked my Speeco quick hitch attach which was adjusted correctly. That's when I discovered this had happened??? No "freakin" idea what I did or may have hit while working the BB. Bottom line is I have to get it fixed. Ordered new left and right hand hitch straps that will be here on Tuesday. Around $28 dollars a piece plus $11 shipping. This had to have occurred while pushing dirt vs pulling?? Wondering if anyone has had this happen? Also, once I get the new straps on Tuesday...would it be worth my while to weld on some reinforcment pieces to each strap to make them a littler more "beefier"???
I realize this post is years too late, but it is relavent to people who may have a BB12 box blade or thinking of purchasing one. Note that the Operators Manual indicates (in the enclosed picture) that there are suppose to be 2 bolts at the bottom of each side of the A-Frame (to prevent rotation). Incidently, I have a 2020 L2501 with a BB1260 that came from the dealer that was set up with only one bolt on each side the A frame bottom (going to change that prior to the next use)......
