hst pedal sticking
jake044
l2800, front bucket, back hoe
Apr 21, 2021
Higganum Ct
Hst pedal sticks going forward (L2800). It's ok for about ten minutes after being lubed. Lithium lube lasts longer than regular grease. Has been this way from day one. Any solutions to this?
Motion
Kubota MX5100HST/FEL
Aug 17, 2020
586
338
Mandeville Louisiana
Does it only stick in forward, what about reverse? To unstick it, I assume you need to step on reverse. Be careful if someone other than yourself drives the tractor, until this issue is resolved. Is there any other linkage or components which could cause the sticking. If lubricating the exterior components helps then that should eliminate the transmission. Are you certain that the lithium is penetrating into the pivot points. Consider cleaning very good and try some Kroil, Mouse Milk, PB Blaster or any thin penetrant.
3,090
Check the linkages - as Motion mentioned.... something is binding or not greasing well
jake044
Apr 21, 2021
Higganum Ct
Thank you for the quick reply!
Only sticks in forward. Don't have to do reverse to unstick. It releases under pressure but no way to gently move forward. Couldn't see any other linkage that may cause it. Sprayed all connections I saw with silicone. I will try the cleaning and regrease it.
Thanks again
johnjk
Apr 13, 2017
1,817
2,237
West Mansfield, OH
Do you have a mmm? I have issues with the linkage binding on my B1700 if I don’t have the mower lowered enough
jake044
Apr 21, 2021
Higganum Ct
Rookie here, I'm assuming mmm is mid mount mower. If my assumption is correct, I don't have one. Actually, even if my assumption is wrong, I don't have one.
johnjk
Apr 13, 2017
1,817
2,237
West Mansfield, OH
Sorry. Yes, mid mounted mower.
rentthis
1,010
25
summerville,sc
That tractors HST pedal has a damper cylinder (with corrugated rubber cover). I have replaced those to great success. It could have been faulty when new.
Outdrz
L3901, 525 Loader, 2060 Cutter, EA Toothbar, EA Box Blade, JD Disc and more
Feb 20, 2021
42
34
Sounds like you're just bragging that you got the "poor man's cruise control option"... šŸ˜‰šŸ¤£
Some of us might want to re-create that "problem".... (joking, ofc)
jake044
Apr 21, 2021
Higganum Ct
Thanks rentthis, I don't recall seeing one, but that doesn't mean it's not there. Will do a closer inspection.
jake044
Apr 21, 2021
Higganum Ct
Thanks to all who replied. I found pivot points, hidden under sheet metal, next to the parking brake lever. Been hitting it with silicone. Getting better with each application. My poor buddy went ten years with no lube there. No wonder he argued with me about moving'
