Rear ballast idea - good or bad?
Daylight
BX231, Ortolan T10
Feb 25, 2021
469
835
I have been thinking of a quick and easy way to make a rear ballast for the BX 231, and came up with this idea, which I submit here for the forum’s opinion.
What if I weld a piece of heavy-gauge steel plate (red in the picture) to a 3-point hitch, so I can hang my 4 Kubota suitcase weights (+/- 220 lbs. total)
on it? The separate weights and hitch are easy to move around and store, and a hitch is cheap. Does that make sense?
pokey1416
Jun 24, 2020
567
844
SW Michigan
Is that going to be enough weight for ballast? Sounds good and nice and compact.
5,195
Heavy Hitch has been making something similar for a while. I don’t have one. Never heard any complaints about them, so the general idea has been done and seems to have worked.
Daylight
BX231, Ortolan T10
Feb 25, 2021
469
835
It's only for a little BX231 with a limited front loader capacity. I can try and, if needed, get a couple more weights.
Daylight
BX231, Ortolan T10
Feb 25, 2021
469
835
Thanks for the link!
Looks good, though rather expensive. I can get a decent hitch for the euro-equivalent of $65, and have plenty of scrap steel laying around, so during my next R&R I'll ask my brother to come over with his welder (living on a old 130-ft barge he's become an expert at everything metalworking...).
2,869
Daylight - one thing to consider, the farther out the better the weight - you are adding weight AT the pins - thus more is better, a 350 lb back blade works well because all of the weight is way out past the pins -
The force = weight @ a distance
whereas you are wanting to place weight AT the pins - thus add more, like get up there - 400 lbs or MORE
5,195
Definitely agree. I’m a hack at fabrication but I would cobble something together before buying a Heavy Hitch just to hang weights on. I use a 500+lb box scrape and loaded rears for counterweight but looks to me like you have a solid plan.
SDT
multiple and various
Apr 15, 2018
3,312
1,102
SE, IN
Should work well.
Similar devices are commercially available.
SDT
MNVikingsGuy
LX3310, FEL, 60" bucket, 60" grapple, 60" box blade, 60" flail, LX2980 blower,
Sep 7, 2020
212
148
Minnesota
Had been using the box blade as back ballast, but like the additional maneuverability of smaller footprint of my heavy hitch. It gives me 600 lbs with case weights. Sounds like your project would give you the same benefits.
Daylight
BX231, Ortolan T10
Feb 25, 2021
469
835
You have a good point, but I don't want constant weight. My soil is very fragile (dirt over slate), so I want to tread lightly whenever possible.
Are your rear tires filled? If not you may want to start there.
Daylight
BX231, Ortolan T10
Feb 25, 2021
469
835
Well noted (how did I not think of that myself?) - thanks! Instead of welding the plate on the hitch, I can fabricate a U-shape that sticks out behind it, giving me maybe 4-6 inches more. Given my often limited maneuvering space, overall length is an issue.
19thSF
B2650, loader, MMM, pallet forks, tooth bar, rear blade, JD 318 w/plow, JD X350
Mar 1, 2020
408
123
Glendale, Rhode Island
There is a lower cost alternative. Heavy Hitch make a good product. Titan's is just serviceable. It depends on your budget and product opinion. Good luck with your purchase, or, your idea will accomplish the same thing.
4,318
So what is the prices of suit case weights around the world?
Daylight
BX231, Ortolan T10
Feb 25, 2021
469
835
Here in my little corner of the woods, original 25-kilo Kubota weights are EUR 84 (= $101) apiece, including 21% VAT but without shipping.
man00
197
12
okla
kinda like mine
