Front loader lifting boom ?
Steamer Pete
LX2610
Mar 29, 2021
49
42
Holland, MI
Anyone ever build a lifting boom for their quick attach fork attachment? Thinking like an inverted "L" that are often seen on rigger's for trucks.
I'm considering getting an old fork with the correct mounts, cut off the horizontal portion of it, weld a piece of 3" tube on the face of the fork about 2' taller than the fork attachment plate, then sticking out 2' or so from the tractor with a good lifting eye. This whole thing would allow the lifting point of my loader to be about 3' higher than if I were to be lifting directly from a fork.
Just looking for ideas or lessons learned. I understand the farther I go from the tractor while lifting, the max load drops.
Thanx !
i7win7
Feb 21, 2020
3,377
3,993
Central, IL
Recommend much larger tractor, loaded tires and 3pt ballast
BigG
Sep 14, 2018
1,953
774
West Central,FL
Nicfin36
Jun 19, 2019
1,018
472
Decatur, AL
I have one of these. I have not used it yet. I had not planned to put a boom on it, but I suppose something like that could be done with it.
torch
Jun 10, 2016
2,870
1,112
Muskoka, Ont.
I played around with the idea. First with timber lashed to the forks, which was as sketchy as it sounds. Then with a steel boom that started life as a large spreader. Also sketchy and only useful for the lightest of loads:
The Mk. III did away with the forks and got it's own SSQA mount.
The tractor just transports it, in use it rests on the ground:
Transport position:
UpNorthMI
May 12, 2020
849
567
Up North, MI
Thanx !
Take a look at pallet forks.com they sell a 60” tree boom, I have one that I use on my MX and track loader.
unfortunately the loader on a LX is going to struggle to lift anything too heavy as you push the lifting point forward of the pins. If your use is not too heavy the tree boom is very useful.
