I have a 1990's vintage B2100 with the 3 cylinder diesel lookup says D1005-D10 engine.
I have owned the tractor for about 5 years , and have changed oil, filters, fuel filters, and just started using off road diesel in the rig.
It was used hard in December to snow blow 2 foot of snow off a 700 foot long driveway. No issues... worked/ran fine.
Winter is over, and I installed the box blade on the rear 3-pt hitch to move some top soil around and again it ran perfect for about 15 minutes, the suddenly started to die.. and now will start but it appears that only 1 cylinder is running, and it refuses to rev up at all. This was a sudden change. Oil level is fine, air filter is clean, pulled fuel filter and it looked good, and with it removed the fuel flows in a nice flow with the fuel valve open. So.. it appears to have fuel flow (at least to the filter on the lower RHS of the engine).
Since it starts, but barely runs , just sputters.. I am guessing fuel pump has failed? Or do others have other ideas on things to check.
Unit has about 700 hours and is not used hard, mostly to drag the box blade once a year, and to mow with the 60 inch belly mower.
I located the factory service manuals for this exact model B2100, and have started looking at the troubleshooting steps.
Suggestions anyone on what to check next? I don't want to just throw new parts at it.
Thank you in advance
CPU
CPU
