What lies Beneath!
OrangeKrush
Nov 15, 2020
1,047
515
Indy
I’m curious as to how many of you may have found rust under your floor mats. I’m sure there may be some that’s never taken the mat up but you may want to check on it.
I have only 23 hours on mine so not much to worry about at this time but if left alone I could see this corroding quicker than wanted. Other than removing fairly often and cleaning and waxing it, I don’t know what else you could do. The back of the mat is cleated and there are holes in floor board for drainage but mine was still holding water days later.
Just something to think about if you have not ever taken it off. Much easier with Auto body & interior panel tools. Those suckers were tight and I would have destroyed them without that tool. Not that you can’t replace them cheap enough but just one more thing to have to remember to get.
BX2680
je1279
Dec 6, 2020
728
469
Upstate NY
Well that's concerning. I will certainly check mine.
PaulR
Aug 3, 2020
579
459
Hadley, MA
Yea.
Northeast=snow, salt sprays + me snowblowing and driving down the road.
I should lift up my mats like yesterday and fix this.
wait, who my kidding, forecast is for a foot of snow in the next 24 hours, lol
2,551
I took my floor mat off my BX about three years ago - cleaned the area up a bit - sprayed some of the "bed liner" spray down and then bought the heavier mat that I saw first on a Paul Short video...... I like the thicker mat a lot better than the OEM.
I think the thicker mats became a standard sometime after the BX25D's first couple of years.
3,316
I have a RTV-X900 which has a rubber mat across the floor and I’ve heard other RTV owners complain about their floorboards rusting out as the result. I was thinking about removing it and inspecting/cleaning the area up... the mat only seems attached with plastic buttons, so it should be fairly straightforward.
However, your mentioning truck-bed-spray seems a great solution... Maybe I don’t really need a mat if I do that.... Hmmmnnn.
gened14
Kubota B26 TLB, ZD 1211, ZG23, Allis Chalmers D17 series IV, Allis Chalmers 170
Jul 7, 2014
20
Tennessee
I also used spray on bed liner on the floor of my B26. Works good.
I have also used it on my antique tractors on the floors and also to coat the inside of their tool boxes.
Steve Neul
B5200
Jun 3, 2017
130
14
Terrell, TX
I would think if you had only 23 hours on the tractor Kubota would warranty it.
If you are going to take care of it yourself, if the metal is rusting you need to strip the paint down to the metal and use an epoxy primer and then paint it. You won't have anymore problems with rust.
Crash277
BX23S
Jan 17, 2021
846
622
good timing on the question, I washed My machine the other day and was contemplating pulling the rubber off and washing under it. What type of anti-rust spray I could use that won’t mess with the rubber? I did debate on cleaning it and coating It with por15.
OrangeKrush
Nov 15, 2020
1,047
515
Indy
Yea.
Really.. snow.. it’s been so nice here I forgot that we could get it in May. Not likely but I have seen it!
OrangeKrush
Nov 15, 2020
1,047
515
Indy
Sorry if my post was misleading.. mine doesn’t have rust but I could see where it could easily rust without some attention.
Thanks for the suggestion on the fix!
If I ever need it.. hopefully not!
OrangeKrush
Nov 15, 2020
1,047
515
Indy
Good idea with spray liner, and I think mine does have a heavier mat. I did see Paul installing one on something.
Steve Neul
B5200
Jun 3, 2017
130
14
Terrell, TX
I thought I could see some rust in spots in the picture. Depending on how the metal was finished rust can spread out under the paint and get bigger than what you see. This is the benefit of epoxy primer. If there is a scratch or damage to the paint down to the metal the rust would be isolated to the scratch.
OrangeKrush
Nov 15, 2020
1,047
515
Indy
I was trying to show the puddles of water plus there was some dry dirt along with a little mud. It looks new again but you can tell where the most used spot is.. and that’s where you place your foot for upward approach.
Motion
Kubota MX5100HST/FEL
Aug 17, 2020
540
302
Mandeville Louisiana
Not sure if Kubota stamps their own sheet metal or if they outsource, but in dream world, it'd be nice if they would offer floor pans in a good grade stainless steel.
