NoJacketRequired
I've come up empty in my searches so, once again, I'll reach out to the great mind trust here at OTT!
I have a B7510 with a very old quick hitch - its label is missing. I suspect it might even have been from an earlier model like a B2400. It's a pure bolt-on quick hitch.
I'm looking to move to a newer quick hitch, one that I can install and remove more readily. My other B7510 has a hitch which hooks onto the tractor's front frame crossmember with a threaded clamp arrangement and at the aft end it uses a single long round pin to pick up on two frame-attached lugs. It mounts and dismounts from the tractor in minutes.
I've found a B2741C quick hitch on the used market and am trying to figure out if it will fit my B7510. I'm having a devil of a time finding any form of cross-compatibility information on these quick hitches. Any help you might be able to provide in determining which quick hitches will fit the B7510 would be hugely appreciated.
Thanks!
Thanks!
