Front Axle Oil Level
nbryan
Jan 3, 2019
1,368
892
Hadashville, Manitoba, Canada
For the L2501-L4701, both manuals do not mention 80w90. It recommends SUDT2 or SAE 80 - SAE 90 gear oil. Both SAE 80 - SAE 90 are straight weight
Try to find a straight weight 80W or 90W gear oil. Unlikely, as the 80W-90 is all that's generally available does the job. It's 80W when cold and 90W warmed up. That "SAE 80 - SAE 90 gear oil" is likely one of the many interesting manual "typos", I think. Says that in my B2650 operator's manual too. Just use 80W-90 multigrade. Or SUDT2. And don't mix.
old and tired
1,919
1,297
If you are low, replacing the oil is not going to be much volume. Open the drain, if it pours out, it's NOT 80w90. I plan to drain mine again just to see what the oil is like (any metal in there?). Such little volume compared to 7.5 gallons of hydraulic oil. Cheap oil change.
MSG H
L3901 HST RETIRED MIL.
Dec 20, 2020
45
20
VA
Exactly,
Can it be confirmed that the tractors front axle is shipped new with kubota hydraulic oil or gear oil? Full or not.
Nicfin36
Jun 19, 2019
1,018
470
Decatur, AL
My salesman said they use UDT fluid in just about everything except engines....and my front axle. :(
I don't think it would matter much if you had 1/2 gear oil and 1/2 UDT. But, many up north say they run UDT/Super UDT in theirs, and those in the south run 80W90, which is what I used.
3,766
80/90 gear oil is easy to detect.... It smells strongly like garlic. (At least the modern GL5 stuff does, due to the EP additives in it.) It’s a great general purpose gear oil which is why Kubota OK’s it for front axles.
Don’t get hung-up on the literal 80 or 90 wt terminology. 80/90, SAE80W90, etc etc is what is intended and it’s fine.
kubotafreak
Sep 20, 2018
1,049
398
Arkansas, US
Mine had udt2, it was low at the dealer. I had a wrench with me to check it. I don't know how much he added, but it didn't show on the end of the level plug, even after going up the incline of the trailer. (l6060)
forky
Feb 23, 2021
325
358
Wisconsin
Still trying to figure out the front axle. On the backside I have 2 bolts on the corners that are only screwed in halfway. Are these vents for draining?
Also a question on why it doesn't seem a drain is on the very bottom....sorry for being ignorant on this. Any explanation would be appreciated. I would love to check my fluid level with only 1 hour on the tractor. Dealer said I was good to go on fluid levels.... 😉
PNWBXer
BX2380
Feb 24, 2020
151
Washington
I could be wrong but those 2 bolts on the back side might be steering limit screws? At least that's what I think they are (on a BX2380 anyway).....but too lazy to look up in my tired state. The vents are on top of the axle right by each wheel and the drain plugs are on the bottom of the actual axle. Those 2 bolts are on the hub I think? and not on the axle....again for a BX...not an L ...but I assume they are close.
3,341
1,762
The bolts you are seeing installed halfway are indeed the steering stops, they limit how sharp you can turn.
You have a drain plug just up from the bottom for each knuckle, they take a 14mm socket to remove.
There are no vent plugs on top of the knuckles used on L2501's.
You will have a 14mm head plug on the axle tube to check the oil level and a 26 mm-headed plug to fill through.
ayak
L3301 HST
Feb 16, 2018
728
1,080
WV
If you hadn’t already found it, look for one of these drain plugs (item-30) on each side:
ken erickson
Nov 21, 2010
1,325
2,336
Waupaca Wisconsin
From my L2501 owners manual. 1 is the check plug and 2 is the fill plug.
(view, standing in front of tractor looking towards rear.)
Thanks everyone for input on which fluid is used from the factory/dealer!
Bmyers
May 27, 2019
3,528
4,553
Southern Illinois
My L3560 had UDT2 in it and that is what I continue to use in it.
ken erickson
Nov 21, 2010
1,325
2,336
Waupaca Wisconsin
I guess I can join the club with low front axle lubrication levels from the dealer.
Mine was just shy of a quart.
forky
Feb 23, 2021
325
358
Wisconsin
Thanks for all the replies to my questions......cleared up my confusion and understand what's what now. Good folks here!
tradosaurus
Kubota MX5400 HST, Land Pride RCR2660 , EA 60" Xtreme grapple, EA box blade
Mar 7, 2019
97
71
Texarkana, Tx, USA
Just checked mine on my new MX5400 and I had to add about 10 oz. I used 80W/90 gear oil since I had it and didn't need a funnel to pour it in the fill hole. The check plug is a 14 mm and the fill plug was a 25 mm (I used a 1 - 1/16" wrench).
kubotafreak
Sep 20, 2018
1,049
398
Arkansas, US
Looks like someone needs to confirm miscibility of udt and gear oil now... Whoever does, pictures please!
Foaming would be the issue I would worry about.
