Changed shift lever boot on B5200
minthillbill
B5200
Mar 12, 2014
9
Mint Hill, NC
Been a few years since i tried so got it done today. Shift knob was glued to shaft. Heated shaft with propane torch, then used 1/2 in open end wrench under knob and hammer to tap off knob. Changed boot. WATCH OUT, SHAFT IS HOT!
put knob on shaft and tapped into place with hammer.
Steve Neul
B5200
Jun 3, 2017
130
14
Terrell, TX
Unless a DIY has added glue I don't believe the knobs are glued on. I've had mine off several times and it's always difficult to get it off and I've never put glue on mine.
3,471
How’d you get them off?
Steve Neul
B5200
Jun 3, 2017
130
14
Terrell, TX
I wrapped a rag around the knob and used a pipe wrench and twisted it off. Once you get it moving it easily comes off. I have it off now so I could remove the boot. It was easier to take it off than to mask it while I'm painting the frame. I think this time I used a wood clamp to remove it.
kaze
Kubota B7000 Cub Cadet 1782 Cub Cadet 78D York Three point rake Woods RM 400 mo
I had the smaller red knob on my 7000 I just put silicone on the knob and boot and pulled it over Now this 7100 has a larger know that does not turn may try that again.
