trikepilot
B2620HSD w/ LA364 BH65, 48in Bush Hog, Bush Hog rear blade, Woods 5ft Box Blade
I am new to diesel tractors. I bought a 240hr used 2013 B2620 TLB a few months back from my local dealer (one owner trade in). Due to winter... I only used it sporadically (never more than 1hr) since then and it has been in a garage at 50 deg or warmer and on a battery tender since then.
I added a digital voltmeter with 2x USB charging port direct wired to battery. Other than that it was how I got it from dealer.
Used it all day today and it was great... until it would not start. With no warning, I got a click and no start. Voltmeter went to 9.7 under start load. Under no load it reads 12.6. When running voltmeter reads 13.5-13.7 so I am assuming alternator is doing its job.
I figure the battery is likely OEM and has a bad cell. The alt could not keep up with charging it. I say this since under load... it dropped to 9.7. I brought the boat batt out to the tractor and it started and ran just fine. It will not run without any battery connected but my interweb searches indicates this is normal - ie: not a test of a properly operating alternator.
I ordered a new battery online and will pick up at 0800 on Monday. I am on vacay this coming week and gave alot of work slated for the tractor.
So to those more savvy Kubota users... does this sound about right. Weakened battery (7-8 year old) that needs replacement? Same thing happened about 2 mos ago on my RTV400ci and a new batt has fixed it.
Just looking for positive reinforcement...
Thanks
Harrison
Thanks
Harrison
