I recently removed my PTO shaft to clean it. I removed all grease from both yokes and shaft and added new grease. When I reinstalled it, the implement yoke became stuck on the spline before the quick release pin engaged. I tried tapping it off with no luck so then I tried tapping it all the way on with no luck. I used PB Blaster and let it set over night with the same results as earlier. For my next attempt, I used a propane torch to heat the yoke but because of how everything is situated, I couldn't use enough force to tap and remove the yoke. I was able to heat and tap the yoke all the way onto the spline until the disconnect pin ungauged so now at least I can use the implement but I still can't remove the yoke from the spline.
In lieu of advice from this forum, my hope is that using the implement some will loosen up the yoke/spline connection enough so I can separate them.
Any helpful tips or advice will be much appreciated.
