BX23 hydraulic fill
Highrockman
2006 BX23 w/ loader, backhoe , belly mower and grass catcher
Mar 29, 2021
Monroe, WA
Added UDT after a filter change and while a little hard to see the fluid on the stick, it seems about 1/8” over full.
Should I drain or am I ok?
UpNorthMI
May 12, 2020
850
568
Up North, MI
I would not drain, operate your tractor and check it again a day or so later. I would not be worried if it stayed 1/8" over, it has a reservoir and 1/8" is not going to hurt anything. If it drops below full I would top back up to full.
Highrockman
Mar 29, 2021
Monroe, WA
Thanks!
Much appreciated!
SRRGC1
BX1870-1, BX23S TLB, RTV XG850, MX5100DT
Jan 6, 2021
212
75
Bloomsburg
You mentioned using the UDT. Should be using the SUPER UTD, however the regular UDT is not bad. I would worry about an 1/8" either. Did you fill the hyd. filter some prior to installing? Whole another issue of do's and don'ts. Just saying. If you did not, new filter will take up some UDT.
Highrockman
Mar 29, 2021
Monroe, WA
Excellent advice!
Thanks!
