Workshop manual for B5001
LambrechtEmiek
Kubota B5001
Mar 24, 2021
Aalst Belgium
I am repairing, as volunteer on a camping, a B5001 and need a workshop manual. The manuals i downloaded from kubotabooks.com are not very clear as they are scanned at a low dpi.
Who can help me with this or where can i download partlists and service manual.
kindest regards
Emiel
6,981
The manuals available on Kubota books are the best that is out there.
A lot of older manuals lack clarity even in original form!
If your a little more specific on what you need to fix and / or include pictures of what your working on, a lot of us on here can help you get to the bottom of it.
LambrechtEmiek
Kubota B5001
Mar 24, 2021
Aalst Belgium
Thx for the fast response.
I need to open the gearbox and/or differential to find out where the noise comes from. The hard noise can be heard in first gear only, I have been told. Next week i will be able to drive and test the tractor when I have finished repairing the engine)
The only number that looks like a serial number is #80.852 66621-47232
All labels are Japanese.
Next week I will make a video to let you hear the sound. Thx in advance for your help
I have downloaded B5100_B7100__service_manual_part1 part2 and part3 and have found all the information I need.
Thank you very much
6,981
Engine serial number is stamped on a flat facing up right next to the injection pump.
Tractor serial Number will be on side of frame left side by where your foot sits.
LambrechtEmiek
Kubota B5001
Mar 24, 2021
Aalst Belgium
Sorry no serial numbers found on the places you mention
Is this then a so called grey tractor?
Would it help if I send pictures of certain details which could tell you the correct model?
6,981
Yes if you would post pictures of the tractor and the motor, right side and by the injection pump.
There is also a cast Number (CC) on the right side behind the Hydraulic pump that will help too.
And a B5001 is most definitely a grey unit.
LambrechtEmiek
Kubota B5001
Mar 24, 2021
Aalst Belgium
The cast numbers behind the hydraulic pump are:
508CC
810
??AC
?? Stands for a symbol i can’t recognis.
LambrechtEmiek
Kubota B5001
Mar 24, 2021
Aalst Belgium
Thank you very much
The motor is as new with new pistons and piston rings. The shop manual with text in English/Deutsch/Français is excellent.
The noise came from the protection tube around the drive shaft from gearbox to front wheel drive. A few drops of oil on the bushing at the gearbox side have solved the problem.
WELSH BLOKE IN FRANCE
KUBOTA B5001
Dec 1, 2022
FRANCE
HI Did you ever get a manual for your B5001?
Would you be able to tell me where I could get one.
Many thanks in advance
