Mid-mower for a B2710??
ETXKubota
Kubota B2710 w/ front loader, brush hog, & box blade
Dec 21, 2019
Tyler, TX
I’m looking for a mid mower for my B2710 w/ front loader. Ideally I’d like to pick up a 72” mower to help take care of about 5 acres, but I would settle for a 60”. I have a rear brush hog but a lot of my property is wooded and it’s a little cumbersome/ long.
My question is, what all mower models will fit my tractor? I’ve read a bit and have heard the decks are all about the same, but the linkages is what’s different. But I’m totally ignorant. Thanks In advance.
2,759
On Kubota USA site is an illustrated parts list. You can get to it and search your TRACTOR model using the more general model like B2710. You will probably get several results so you can select your specific model. Somewhere it will show a button to push that is named LOCAL OPTIONS. That will list out the model numbers of the factory implements that fit your tractor
3,353
I have a similar tractor a B2910 (actually identical except for HP).
Anyway, I do not have a MMM as I use my BX with MMM for mowing. I would suggest you make sure you understand what you need as far as linkage for the B2710, to mount, raise and lower the mower deck, before you buy a mower deck.
I would imagine the MMM is raised/lowered by the 3PH somehow, as mine is on my BX. You want to be sure you understand what you need to do to make this happen. Not sure if you would get what you need if you purchased a MMM new from Kubota. Hardware for connecting the deck to the tractor may be sold separately.
