currently using straps, however I'm going to switch to chains and binders for the tractor and then will be using my straps for the implements.
I think I will be going overboard on my tie downs but figured it doesn't hurt to double check with the amount of experience on here.
this is what I'm looking at buying.
4x 1/4 to 5/16 in. Chain Load Binder (princessauto.com)
2x 5/16 in. x 20 ft Grade 70 Transport Chain with Grab Hooks (princessauto.com) with the intention to cut them in half so I have one for each corner
my trailer has stake pocket style tie downs that are a PITA, so I'm going to weld something like this
2-1/2 in. Surface-Mount Tie-Down Anchor Ring (princessauto.com) along the top edge so I have more options for tie towns. I will be putting a set of these on the front tractor frame as well.
these are what I currently use 2 in. x 15 ft 5,000 lb Ratchet Tie-Down Strap (princessauto.com)
I will be using 4 corner tie down on the tractor when the back hoe is on as its got tie down loops; when there is no hoe. I will just use one chain in the rear backhoe lower hooks (that's how the dealer had it chained down). Its not required due to weight, however; I will be tossing a strap over whatever is on the loader and on the three point.
Recently our province changed the HTA to allow us to transport personal property without having to have commercial inspections on our trucks and trailers. Previously only RVs were exempt.
if you think I'm out to lunch, or have a suggestion. im all ears (or in this case, all eyes....)
