L8430 stabilizer kit ???
ctfjr
L3800HST
Dec 7, 2009
1,878
2,292
central ct
My new to me L3800 is now 8 years old and the turnbuckle adjusters on the 3 point came pretty crappy looking and difficult to adjust. I've managed to clean them up and greased them thoroughly to get them to move easier but they are what they are. . .
Twice when plowing with my back blade I've had the nuts loosen on the turnbuckles. One I caught on my rear camera when I noticed the blade moving more than it should. The other was found loose during a precheck lookie.
The sway bar kit looks attractive in that, once set it, is never going to move by its self. It's also looks a whole lot easier to set.
My question is to those who have one already. Is the adjustment adequate for your implements? My back blade for example has the turnbuckles set so there is about an inch or so movement side to side. The turnbuckle has infinite adjustment where the sway bar is digital - it has step adjustment.
je1279
Dec 6, 2020
728
469
Upstate NY
The telescoping stabilizers have both round holes and elongated holes to use depending on the amount of movement that you want. You likely have more levels of adjustability with the turn buckles but the telescoping stabilizers make life so much easier.
UpNorthMI
May 12, 2020
850
568
Up North, MI
I fitted these to my L3200 and L3901, this was the best modification I made, they make mounting attachments so much easier, then they are very quick to set the attachments, they have a slotted hole which can be used if you do not want to tighten things up tight.
Easy to fit and replace the turnbuckles. Buy them you will not regret them ever.
wendol
L3800 HST
Feb 5, 2014
194
40
North Tx
Here is a link with the the telescoping stablizers on my L3800 made by Mark Hodge.....plus changing out the lift arms to the Grand L style if you want to make life easier when connecting your equipment.
Ricklesss
L3901
Aug 5, 2020
37
14
Dexter Oregon
I have it and like it although, two comments:
When run with the R4 tires it’s a very close call with rubbing the side walls of the tires at times.
Its important to keep an eye on it, and get the linkage set up with as little slack as possible.
Also, I recommend you get, or make a spare part; the U piece that holds the telescope rod to the tractor, that the 3/8” pin goes through.
Im constantly bending or breaking the pin, and when that happens you can lose the U piece. And that sucks, as it happened to me earlier this afternoon.
Not sure if this is a part that Kubota stocks or not, I cannot find it on the ingernet anywhere yet.
