Trying to find Ballast Box
OrangeHiC
BX1880, 54” Deck, LA344
Feb 27, 2021
26
11
Moore, Oklahoma
Hi everyone
I will give a little background before i ask my question. I bought a BX1500, 48” deck and FEL LA201 back in 2005 and absolutely loved the little machine. It had 505 hrs on it as I mainly used it for a mowing machine and snow removal on my drive (and several neighbors 😀) I never used a ballast box with it. Never had a issue with it in my 15yrs of owning it.
Well, I had a weak moment and saw the 0% interest again so I wound up trading in the little BX and getting a new BX1880 54” deck and FEL.
I love the BX1880 but I have to get used to the differences between the two. I will drive and operate it daily so when I do my first mow, I dont take out the fence LOL.
Ok on with the questions
I want to buy a ballast box and put bags of concrete in it. My problem is I want to buy one in town and can’t seam to find one anywhere. Kubota seams to have quit making them. My dealer cant find one and I called Kubota and they haven’t gotten back with me yet.
What are your recommendation on type and brands? Thanks!
i7win7
Feb 21, 2020
3,377
3,989
Central, IL
Bought mine off amazon, wasn't QH compatible had to mod it.
you may want to consider where to park it when using other 3pt implements. Can be as simple as 4x4's with tree behind them or build a stand.
OrangeHiC
Feb 27, 2021
26
11
Moore, Oklahoma
Nice! I dont have quick hitch but I’m thinking about getting one
5,683
assuming it has a 3PH, buy /make a 'carryall', toss weight onto a skid,use carryall to lift skid of weight. this 'system' make it EASY to pickup the ballast as needed, even have 2 skids , light and heavy, choose what you need for the job....
3,445
Yep... a carry-all is more useful in more ways than simply as ballast.
i7win7
Feb 21, 2020
3,377
3,989
Central, IL
Made one of these also, maybe some I'll figure out a use for it.:unsure:
ctfjr
L3800HST
Dec 7, 2009
1,982
2,535
central ct
I picked mine on Ebay:
Ballast Box
It shipped from NJ and I had it in 2 days. Other than the pins were undersized and I had to change them (lowers) it is very well constructed.
I filled it with concrete (7 80lb bags) and made a frame to go in it with a lifting lug.
OrangeHiC
Feb 27, 2021
26
11
Moore, Oklahoma
I like the carryall idea and I am starting to lean toward the ballast box with the door for emptying.
I could use it for a small dump truck if needed LOL.
Tyler_LaRue
B1700HSD, L4740 HSTC
Sep 25, 2020
I built a black 35 gal drum filled with concrete (500lbs) with a drawbar slipped through. Dropped pvc pipe in it for shovel handles and sunk two plastic ammo cans in the concrete before it dried for tool storage and straps. Works really well. Had the same thing on my larger tractor for years never had an issue. About $50 all in.
UpNorthMI
May 12, 2020
849
566
Up North, MI
I like a nice compact rear ballast box, I use bags of gravel in one of these
El Jefe
B2401
May 18, 2020
37
15
Santa Cruz, CA
I also picked up one of the $250 ballast boxes from ebay. I wanted something more compact than a caryall since I often bring my tractor into tight areas including my workshop where I park it. This is compact enough so that its always on the tractor unless I'm using a different 3ph implement. When I'm not using it I set it down on a furniture dolly ($15 harbor freight) so I can wheel it around the shop and easily align to my 3ph. I like that this box has a 2" receiver and tool holders. I made a chainsaw holder out of a slab of wood and added 450 lbs of sand leaving enough room on top to hold gloves, chains, small hand tools, etc. Only two complaints, the door fits loosely and I had to seal it with silicone to hold the sand and the 3ph pins were undersized but otherwise its great. I figure its 550lbs and when I max out the loader (B2401) I need still need a couple hundred more pounds set on top to keep the back wheels down but its easy enough to throw a few bags of sand or concrete on top of the box. Overall its great and I wish I would have bought a ballast box sooner.
UpNorthMI
May 12, 2020
849
566
Up North, MI
I like your chain saw idea, as I filled mine with bags of gravel, I might just lift them out and insert something similar to carry a chain saw, then put my bags of gravel back in. Like you I have a dolly onto which I unload the ballast box, makes it real easy to store and then to reinstall back on my tractor. For $250 delivered they are great value even if you have to replace the pins, I purchased from Titan several years ago, their pins were good.
NHSleddog
B2650
Dec 19, 2019
2,144
1,837
Southern, NH
I wanted it as small and heavy as possible. I used lead. It weighs just over 800lb but all it does is sit there being heavy. I can load it under or behind the QH.
Fastball
L2900, rear blade, finish mower, 200l sprayer, landscape rake
Feb 9, 2017
86
29
North Okanagan, British Columbia
Ballast Box
Have been trying to find one of those Ebay boxes here in Canada. Either they don't ship to Canada, or the cost of shipping is literally more than the item. I’ve seen shipping costs as high as 250 dollars. Makes me crazy. Even all that Titan stuff - nobody ships to Canada. Those carry-alls you guy get for 150-200 at TSC....they’re over 400 here IF you can find one.
Fastball
Feb 9, 2017
86
29
Do you have an idea how thick that angle iron is on the carry all? Since I cannot find one for sale for nor money, I’m thinking of fabbing one up. Would 1/4 inch be enough? Is 3/8” overkill? My L2900‘s 3-point lift capacity is just over 2000 pounds behind (not at) the pins.
michigander
547
234
Northern Michigan
I'm positive tarter makes the carry all for TSC mine is 1/4" thick 3inch angle iron.
Fastball
Feb 9, 2017
86
29
xrocketengineer
Nov 14, 2020
800
722
Merritt Island, Florida
I am cheap. So, I got a 2 inch trailer hitch receiver:
To use with a subsoiler ripper:
https://www.ebay.com/itm/Titan-Atta...501933&hash=item4457067e36:g:FK8AAOSw1ZpgCvTu
And for ballast I use a 2 inch small car cargo carrier and four blocks of concrete:
