Used Dump Trailer For My BX25D - Video
Killingitcountry
Kubota KX040-4, BX25D, BX2755HD - EXPAND for link to my YouTube Channel :-)
Feb 12, 2021
73
58
Ontario
www.youtube.com
Like UpNorthMI, I have found myself a Berkelmans dump trailer. Mine is used and only 6' long but I think it's going to be perfect (maybe a little big) for the BX. I made a short video of the trip to pick it up as well as showing it off briefly once I got it home. Now I have to get moving on rear remotes.
- James
Crash277
BX23S
Jan 17, 2021
846
622
That’s pretty cool, the bracket attached under the rear of the box. Is that to prevent the frame from tipping when you dump it? Too much rear weight will just lift the 3pt up.
Killingitcountry
Feb 12, 2021
73
58
Ontario
www.youtube.com
I think you might be looking at the tail gate latch mechanism. When you start to dump, that latch drops to allow the tailgate to swing open with gravity. When you lower the dump box to the down position the latch pops back up to prevent the gate from opening while moving. Since I don't have any footage of me actually using the trailer yet ... you should check out Berkelmans own video of the trailer as it shows the features nicely.
- James
2,547
Nice, I like it! Repairs don't look too serious, looks like a great deal.
S-G-R
LX3310
Jun 17, 2020
1,115
2,259
PEI Canada
Nice score! I'd be all over one at that price.
UpNorthMI
May 12, 2020
850
568
Up North, MI
James, it looks great, rim and hub should be an easy repair. I am so ready to get my trailer out but we still have knee deep snow at my place in Northern MI. I’m adding rear remotes to my L3200 next week, at least dealer is, so all my tractors have rear remotes.
I think the 6’ is a nice compact size for smaller tractor, I purchased 8’ as most of my use will be timber hauling for firewood and brush hauling to a burn pile.
The jack is well built, many times I will use mine alone, so will use my L3901 that has a FEL and small grapple. I will jack it, detach it, load it, attach it again and then transport. When I have help, L3200 to pull trailer and L3901 to load.
I see another tractor in your future! Good luck with your tilt trailer, excellent value purchase.
Killingitcountry
Feb 12, 2021
73
58
Ontario
www.youtube.com
I have to pay for the KX040 coming this spring first haha. I hear you about the snow.
Killingitcountry
Feb 12, 2021
73
58
Ontario
www.youtube.com
Well I got both wheel hubs replaced and one new rim - so I suppose you could call this dump trailer “restored” and ready to go! I used hub kits suitable for “most 3500 lb axles” which may mean I have effectively reduced the capacity of the trailer slightly but I’m fine with that (2-ton dump trailer) ..... the BX will be the limiting factor, not the hubs/bearings.
I’ve got a video uploading covering the hub replacement and I will post it when my slooooowww country-internet finishes.
- James
S-G-R
LX3310
Jun 17, 2020
1,115
2,259
PEI Canada
Have you seen this option for rear hydraulics?
RogerAU
BX23S
Mar 7, 2021
Victoria Australia
Finally uploaded ...
- James
Nice video, can I please repectfully suggest that you point out (visually or verbally) the safety supports you used when hitting the stub axles out. As a first responder and ER nurse in a rural area, I have had the unfortunate job of pulling people out from under cars and equipment that they worked on with only a hydralic wheeled jack when either the load fell off the jack, the jack lowered due to malfiunction or accidental releasing of the valve.
Killingitcountry
Feb 12, 2021
73
58
Ontario
www.youtube.com
Thank you for your comment! At the 26:00 minute mark I point out, visualy by on-screen text, that "you should support the trailer with an axle stand for added safety". I don't always practice what I preach but I'm getting better. Thank you for your service as a first responder.
- James
