New member from Dansville,NY
Velle01
BX1860
Sep 2, 2020
14
11
Dansville, NY
I don't think that drilling and tapping epoxy will hold. Have you thought about using anchor bolts instead? They come in several sizes but here is just one example,
I had thought about anchor bolts. The draw back is that the bolt exerts outward pressure to hold it in place. I think that pressure will break the plastic. I have used epoxy method before. This was 20 years ago.
armylifer
Mar 26, 2013
2,061
787
Thurston County, WA
I didn't realize the part was plastic. The epoxy method has as good a chance of working as any other on plastic.
2,828
1,544
I would recommend these inserts. I don't know if you can screw them into the epoxy after it has set though. If the tapping strips out, you could glue these in.
Velle01
BX1860
Sep 2, 2020
14
11
Dansville, NY
Wow it’s been a while since I’ve posted. Krusty is all back together and has been a great addition. I found a 60” deck that works better than I though. I have also found a front mount for a dirt/snow blade. I am currently fabing my garden way blade to fit. I also just bought a swisher dirt bucket. I will fab up a hitch for that also.
