So question regarding rear ballast weight. The manual doesn't state a maximum or minimum for a rear ballast. It does mention using an implement as a rear ballast, like a box blade which they estimate would be 420 lbs. It does specify the maximum for the front oddly enough. Right now I plan on running a heavyhitch, along with six 70lb weights on the rear for the FEL. My question is:
a) is this enough?
b) should i also fill the tires?
Thoughts?
Appreciate your time
a) is this enough?
Thoughts?
