Dumb 4WD Question
MNVikingsGuy
LX3310, FEL, 60" bucket, 60" grapple, 60" box blade, 60" flail, LX2980 blower,
Sep 7, 2020
212
148
Minnesota
Is there a reason I shouldn't just leave my new LX3310 in 4WD mode at all times? It is used in woodlands, trails, gravel, and pasture, never on pavement of any kind and rarely on "the lawn". I also don't really care about "gas mileage" unless it was a dramatic difference. The only reason I am asking, is since it is an option for the user, it implies I might only use it occasionally. Will it add unnecessary wear and tear on the tractor if I am fulltime 4WD? Should I leave in 2WD and only switch when I really need it? Given my land can be snowy, icy, wet, muddy, swampy, etc just seems easier/better to leave on full time. Your thoughts?
retired farmer
tractor, loader, cutter, blade
May 25, 2020
188
107
sheridan
I like to take my L3301 out of 4X when not needed, if I can remember to do so. Makes sense to me taking it out would save wear and tear on some parts but not sure which parts that would be.
3,058
There are going to be MANY opinions on this .........
my 2 cents........
I have 2 B7100 that cut grass all the time.... on grass - hills and slopes ........ I LEAVE IT in 4WD all the time.........ALL the time!!! It helps me pull up a crazy right turn when cutting a portion of my grass - it helps brake the tractor going down the steep hills I have to cut..... I too rarely if ever are on "solid" ground.
Been doing this for years ......
On my BX25D - I am in 4 wheel drive when going down hill ........ but if I need to move on good hard ground - I will take it out of the 4WD ..... the lever is right there and poof in and out quickly.
IF I am in the woods and it is wet - 4WD...... if bucket is full - 4WD.......... if moving from point to point in high range ....... 2WD and High gear.
I would say as Clint Eastwood would say ........ " A man's got to know his limitations!" - so, IF YOU know that there is always a place for the wheels NOT to bind .......... leave IN 4WD ........ the one time you take it out and place in 2WD is the one time you go down a steep grade..... and ass end slides..... you pucker up - and then need to change your shorts or worse you will wish it was in 4WD.
These machines are almost bullet and idiot proof ........ I say almost - there are those that can screw up a one car funeral. But as long as you know what surface you are on.... stick with it!
je1279
Dec 6, 2020
834
585
Upstate NY
I don't see why not. I only switch to 2WD if I don't want to tear up the lawn when turning or if I'm on a clear asphalt surface where I don't want it to bind when turning.
Bmyers
May 27, 2019
3,634
4,935
Southern Illinois
I leave my tractor in 4-wheel drive unless I get out on the roads. I tried it out of 4 wheel drive and found that within 15 minutes I was putting it back in to 4-wheel because I was spinning the back tires.
4,204
If only Clint Eastwood KNEW how limited he is...
3,396
Flat terrain or hilly? Hilly here. My B2910 has been in 4WD close to 100 percent of the time over the last 18 years...
If it were flat here, I would probably be in 2WD most of the time...but it is not.
On pavement NO 4WD as mentioned. But I do not have any pavement.
MNVikingsGuy
Sep 7, 2020
212
148
Minnesota
Mostly flat. But if you have been 4WD for 18yrs sounds like no reason for me to mess with flipping back and forth and regretting if I missed a moment where the traction was reduced. (expect of course on pavement and lawns)
troverman
Jun 9, 2015
1,178
266
NH
Its good to go back and forth between modes just to keep the linkage free...
Freeheeler
b2650 tlb
Aug 16, 2018
706
527
Knoxville, TN
Mine lives in the mancave, concrete floor, so I leave it in 2wd unless I need 4wd. If I accidently forget to put in back to 2wd before going back into the mancave, it will quickly remind me as soon as I try to make that right angle turn on concrete. Leaving it in 4wd all the time as long as it's not on pavement might cause a little more wear and tear, but if you have to rebuild the front axle in 32 years instead of 35 years, does that really matter? Not in my book. These things are pretty stout.
troverman
Jun 9, 2015
1,178
266
NH
I wish these Kubotas would have a dashboard indicator of 4x4 engaged...
JohnMackenzie
B6200, L3901, LA525, BH77, MK Martin 60" Mower, Agrotrend C60, ect.
Oct 7, 2020
Ontario
As everyone else said I also mostly leave mine in 4wd unless on the grass and asphalt, I live on a hill so sometimes put it in 4 wheel just to go up and down a specific part of the lawn when mowing, other than that if I'm on the trails in the woods it's in 4 wheel, I find I can turn sharper and smoother in 2 wheel though but it depends on the situation. I haven't taken mine out of 4 wheel since the snow first flew in December, mostly comes down to your own discretion and what you feel comfortable with, but it won't really hurt if its in 4 wheel off of pavement, might just scuff up what you're driving on
bcp
BX2360
Apr 20, 2011
644
80
SW WA
Sidehill property. No pavement. No lawn. Always on gravel or dirt. Hasn't been out of 4WD in several years.
Bruce
old and tired
1,919
1,297
Since 2005, except for an awh chit moment (or two) of not having it in 4x4... it stays engaged. I'll happy pay that repair bill, if and when it comes...
aaluck
Oct 9, 2019
1,002
844
Snowdoun, AL
I use the 4WD when I need it. When I don't it stays in 2WD--just like my truck. Not sure that it would hurt to keep it there but since its an OPTION, rather than sent out of the factory 4WD leads to believe there may be a reason for that.
random
Nov 2, 2020
716
401
NC
Please elaborate.
I haven't taken mine out of 4WD since getting it 5 years ago.
bcp
BX2360
Apr 20, 2011
644
80
SW WA
2WD is my "OPTION" and 4WD is standard. it all depends on your situation.
I would have worn out 5 shift levers by now if I shifted every time 2WD was OK to use. :D
Bruce
6,686
Please elaborate.
Not at all sure it’s applicable to tractors but for selectable 2WD/4WD trucks and SUV’s that are left in 2WD and not at least cycled into 4WD for many years, sometimes the splines will get stuck and won’t slide to engage 4WD. Seen it a few times. Not necessarily common but a PITA if it happens as it results in a trip to a transmission shop or a 4WD vehicle that’s relegated to 2WD only. If you never, ever take it out of 4WD don’t know why you’d care if it’s stuck in 4WD.
