I have the need for occasional use of pallet forks. Not often but when ya need them ya need them. On my last tractor I found a used set for about $350. They were quick attach and 42" long. Suited my purposes perfectly.
With my current tractor, an L3800H, I don't want to give up lifting capacity so weight is a concern. The Fel is only rated at about 1000lbs (depending how high, how far out).
With that in mind I found this Titan unit on Amazon: Forks
I can't see me trying to lift anything much above 800lbs (like 3pt attachments). This unit weighs in at just under 300lbs but is rated for 3000lbs. Is there a lighter, lighter weight unit around that might be a better choice?
