Black smoke
mendonsy
B7500HST/LA302
May 28, 2012
350
31
Mendon, NY
Black smoke is a rich fuel mixture so an injector issue is a possibility but before you go too far down that road you should make sure that air is getting into the engine properly. Check the air intake and air filter for any restrictions.
2,586
Ditto to what mendonsy said ----- sometimes a mouse can get into the air filter- build a nest and the engine blows black smoke from lack of air.
Wayne1978
Ky
Ok will check.
Ok will do.
3,326
SNOW can be sucked into the air filter cannister and cause this also!
1,448
Well I will let you get away with commenting on snow this week.
Another unhappy Texan for this week.
OlFerguson
4440, 1120D
Jun 1, 2017
192
11
Have you tried am additive ? Try the obvious stuff first before you go digging deeper i.e your engine rings
Wayne1978
Ky
No code has to be inserted here.
I am getting a lot of comments on this and I do appreciate all of them, thanks wayne
so i should have started from the beginning, I lost my fuel pressure so I replaced the fuel pump. Lost all fuel in lines.so I took air hose and put air pressure to the fuel tank. Then I got fuel to the pump. Tractor started run good. Then I saw I had a fuel line leaking. shut the tractor off tightened them. Then put air to the fuel tank again because it wouldnt start again. After that it started but blows out lot of black smoke. I am thinking I may damaged a fuel injector or something else. Thoughts?
2,586
I am curious............
How did you do this " I took air hose and put air pressure to the fuel tank " ?????
Why did you not just bleed the entire system with bleeder valve near the injector pump?
