Issue started last Fall; sputtering/near dying whenever pto in operation (mowing). Tractor idles fine and restarts.. Changed fuel filter under tractor which appeared dirty. Bled and restarted and had been running fine for 3/4 tank worth of snowblowing this winter but recently went back into starvation mode to the point of once snowthrower is engaged will not stay running. I do not have heated shop. Thinking I may need to do either and/or all of these options:
- add some kind of conditioner?
1.Change filter again and see if I get lucky and stays running
2. Change filter and drain tank and check for debris inside tank?
Any other suggestions greatly appreciated!
Haven't looked into difficulty of draining tank. It's so cold here in Iowa (single digits and heading for below zero temps so dreading
working in cold shop. I just jumped aboard on this forum and am thankful to find. Hopefully I can find detailed thread for doing fuel filter modification that I read in recent post.
