I have a leak that comes and goes. Right now it 'comes'--maybe because of the cold weather. To be clear, it leaked (very little) this summer in June/July time frame. I figured that I didn't tighten the drain plug good enough on the last change, so I changed the gear oil again the the leak 'stopped' until last week. AND its way worse than last time. I know this because I would check the tire before every use in the summer, which is at least once a week to mow, usually more. Seemed to have started again after I dug some holes with auger last weekend.
I'm fairly handy and have the workshop manual but feel like this may be a bigger job than I can handle. Can someone maybe tell me how big a job it will be and from the pictures what the problem may be? I'm assuming its the gasket.
Thanks
Thanks
