Pressure Gauge Threads?
kbrothers
b2150 HST loader/hoe
Dec 1, 2013
84
Ebensburg,Pa
Going to get a Pressure gauge from Bolt on Hooks they offer one of 3 fitting types What type would my B2150 withLA350 loader most likely have Thanks Ken
5,235
1,018
Some owners feel they have to Tee into the hydraulic line to see what is happening with the relief valve setting.
That is unnecessary.
Assuming your loader has quick connects, you want a pressure gauge that has a quick connect fitting. You unplug one of the loader lines and plug in the gauge. Move your control to direct flow to the gauge and read your relief valve setting. A few seconds and you have the answer.
You can buy a 0-3,000 psi gauge anywhere including a local hydraulics shop and they can provide a male quick connect fitting to fit the gauge they supply.
2,551
I agree with Dave ..... no TEE needed ..... the parts are about 20 bucks or so....
the kit costs over 50 bucks......
yup - I bought a kit too - 7 years ago - live and learn!!! Now I would piece it together!
DrankTheOrangeKoolaid
M6800/M920, Case 780B
Sep 24, 2019
99
34
Alberta
I built mine using a tee and a male and female quick connect. I need the female end to connect to the FEL valve and the male end to connect to the rear remotes. And I can use it inline or not... for the cost of a couple fittings I liked the flexibility it gave me.
