Fuel delivery
armylifer
Mar 26, 2013
2,218
980
Thurston County, WA
That is a fine looking setup. How do you intend to re-fill the drum?
5,257
1,047
I have a similar setup but with a 500 gal bulk tank.
A practice I have followed for years is before each refueling, I pump some fuel from the hose back into the tank to flush out the hose.
This gives the Golden rod water filter a second chance to block any condensation in the hose from reaching the tank.
Botabart
L2501
Jan 1, 2021
22
12
NW Pennsylvania
Did my first fill with my funnel in the 3/4" hole to see if it would work and be able to keep the pump assembly in. It worked fine. Barrel in the truck and unload it with the pallet forks.
B737
LX3310
Jun 9, 2019
2,022
2,205
This is awesome! can you go into a little more detail about the parts you used? came out super clean
Botabart
L2501
Jan 1, 2021
22
12
NW Pennsylvania
It's a fill-rite fr112 pump. The pump and filter and water separator sold as an assembly on Amazon for $224. I used stainless nipples and fittings. The barrel is a 40 gallon stainless steel that I got brand new from a local maple syrup supplier for $205. I have a barrel dolly on its way.
SidecarFlip
Banned
562
Mine is a 1000 gallon self berming ASTM certified fuel tank that I have my local fuel supplier fill when needed, but I also watch how the pricing is. Mine is hard plumbed to the standby diesel generator and I use a 110 volt Fill rite pump and hose with shutoff nozzle to fill the tractors and a spin on water block filter in line. The tank was free years ago. Came with a 5 year contract with the supplier I use. They did the install and maintenance too.
NHSleddog
B2650
Dec 19, 2019
2,144
1,837
Southern, NH
Personally, I would invest in an electric pump. Not for ease of transfer, but to aid in seeing the level in the tank.
Manual keeps you standing at the pump cranking. Electric has you standing at the end of the hose watching.
The fuel and mess saved over time will easily pay for the pump.
SidecarFlip
Banned
562
Most storage tanks come with a level float installed, at least all the ones I've seen do but probably not the 'repurposed' ones.
Botabart
L2501
Jan 1, 2021
22
12
NW Pennsylvania
I get my off road diesel from the same company that del
I've always been able to hear when it's getting full. Was filling big farm tractors with a hand crank when I was about 10 years old. Anyway I'm ordering a grand L soon so fill will be down low where I can watch it.
ctfjr
L3800HST
Dec 7, 2009
1,982
2,538
central ct
To be sure my requirements are a whole lot less than most of the posters here :)
That said its getting to be a pia to lift 5 gallon jugs onto the hood to fill the tractor (and scratch the hood when the rag moves). I just got this in yesterday:
My generator is right next to where the tractor is parked so I can fill both easily and obtain power from one of the genset batteries. I assembled it and tried it out. It drained a 5 gallon jug in seconds. The kit comes with a pretty long outlet hose, nozzle and all required fittings including a filter on the suction side.'
Its a pretty small device and I'm going to mount it on the wall. For me its perfect.
Mark_BX25D
Bx25D
Jul 19, 2020
1,891
1,371
I have one that is very similar. It does the job for now.
I also have a home heating oil tank which I got half full from a Craigslist ad. (I actually got my 12v pump to help me pump the tank out so I could move it.) I plan to pour a slab and mount it there, and run 120 to it, then buy a real 120v pump and fit it with a filter setup. I figure the money I have saved in fuel by scrounging home heating oil from Craigslist will make the pump pretty close to free.
7,000
Looks like we have a sidecarflip and a sidecarflop. One has a 1000 gallon storage tank, one has a 2000 gallon storage tank. A lot of confusion just for an explanation of fuel storage. Maybe one forgot the other one posted!
3,253
Around here they seem to insist that you put your container on the ground before filling, even with diesel fuel.
Not sure how "Barrel in the truck" would work here...Suppose it might if they were not looking or did not care. Pumps do have a notice that containers must be placed on the ground.
Would not bother me at all filling diesel into a container on the truck.
armylifer
Mar 26, 2013
2,218
980
Thurston County, WA
Why is Sidecarflip BANNED? Sidecarflop should be banned for purposely hijacking another member's avatar and making fun of his screen name and attempting to ridicule another paying member. This is outrageous!
Think about it this way, your avatar identifies you on a forum. To hijack another member's avatar is the same as identity theft. Think about it as if it was your avatar being hijacked.
3,253
Flip banned? News to me. Where did you turn this up? I’m always the last to know,,,I’ve learned to live with it though...
armylifer
Mar 26, 2013
2,218
980
Thurston County, WA
Scroll to any post made by him and it says Banned under his screen name.
