Thanks!I don't use it a lot, so probably somewhere in the 13-15 hour range. I had the dealership install them and rear remotes at the same time.
You did not mention if you have a MMM (mid mount mower) on your tractor. If you add wheel spacers, it may affect the MMM anti-scalping rear wheels. I know in some "B" series, individuals would install wheel spacers in order to increase space for tire chains, however would have to remove spacers when they reinstalled their MMM. Additionally, rear tire ballast would help in tractor stability on hills. If you have a FEL (front end loader) you always should have rear tires loaded and/or rear ballast.My land has some slopes and hills that I just avoid. To add stability am considering adding a Bora 3.5" wheel spacer to each side of rear. Anyone tried spacers? If so, how well did they work and did they cause any maintenance issues. Thanks.
He has a L3901 which does not have that option.You did not mention if you have a MMM...
10-4, guess he doesn't need to worry about that then. Spacers should help with stability.He has a L3901 which does not have that option.
I don't have a MMM, but it is a good point, as is the tire ballast comment. Thanks.You did not mention if you have a MMM (mid mount mower) on your tractor. If you add wheel spacers, it may affect the MMM anti-scalping rear wheels. I know in some "B" series, individuals would install wheel spacers in order to increase space for tire chains, however would have to remove spacers when they reinstalled their MMM. Additionally, rear tire ballast would help in tractor stability on hills. If you have a FEL (front end loader) you always should have rear tires loaded and/or rear ballast.
Thanks !! Exactly the answer I was looking for.Spacers and your model have been out for a while... if there was a problem, it would have shown up here in these forums by now... Let us know how they turn out...
