Did my first 10 hour loader lube. Re positioned the loader hose protective sleeve in order to keep the hoses from rubbing on the loader frame (one was rubbed through the outer jacket to the steel braid). Re positioned the protective sleeve on the TnT return line where it was starting to rub into its outer jacket. Tightened a TnT line where it was seeping at the valves. Checked levels. Topped the coolant reservoir.
