An observation from many years ago inspecting failed tires that when you wanted to cut a tire, wet it and the knife will glide through the rubber.
The lesson I learned from this was to avoid thorns and the like when either they or the tire was wet as a puncture was much more likely. The water was like a lubricant making tire carcass penetration much easier.
Very interesting. I will keep that in mind.
I have a few locust trees that I would like to see gone. I don't want to get my tractor near them. I was running the brush cutter along my fence line last year and there are some trees on my neighbor's side of the fence that have branches which extend over on my side. As I got to each branch, I would reach out and push them up and over my head. Well, I did that with a pine branch and did not realize there was a locust branch intertwined with the pine branch and as I pushed the pine branch over my head, the locust branch came loose and hit me in the face. It split open part of my chin and lower lip. (Thank goodness it did not get me in the eye.) I felt like the thorn was broke off and stuck in my face, but it was just the cut. I had some super glue and glued the cut back together. Worked quite well.
