Hood gasket
Bmyers
May 27, 2019
3,456
4,310
Southern Illinois
One side of my hood gasket is coming loose. What should I use to 'glue' it back into place? I pushed the rubber gasket back on, but it doesn't hold, as soon as you open the hood, the gasket is dangling.
Any recommendations would be appreciated.
Thanks
3,199
1,620
Thanks
We use 3M trim glue, several brands are available and will work equally well.
Bmyers
May 27, 2019
3,456
4,310
Southern Illinois
Thank you, I will try to pick up some tomorrow when I hit Farm and Home
DeepWoods
B2650HSDC Woodland Mills WC68 Wood Chipper
Apr 10, 2019
342
282
Bigfork Minnesota
I used clear silicone on my loose gasket two years ago. Still there, and has never fallen off. Plus clear wont show if misapplied.
Rcflyer330
Kubota B2650 Cab, B2779 Broom, B2782B Snowblower, RB1672 rear blade
Oct 14, 2019
112
62
Traverse City, Michigan
Last year on my b2650 the bottom hood gasket would not stay on the hood when put back. I found out by trial and error there is a metal C channel that is molded into the rubber gasket that became deformed. I fixed it but removing the gasket and squeezing it between my fingers to make the gap smaller and reinstalled. I have had no problems since and no tools or adhesives needed.
Bmyers
May 27, 2019
3,456
4,310
Southern Illinois
I will have to take a look.
Orange1forme
B2650 HSDC, filled tires, wheel spacers, B2728B , LA534A FEL, 3rd valve kit
Dec 1, 2018
397
60
Wa
My B2650 kept coming off last year and I finally just kept it off.
I thought about adhesive to keep it on but was worried about it freezing and then ripping when I opened the hood.
I have left it off since and have not though anymore about it, until now.
ironbender
B2650; loader/bucket; forks; bush hog; box blade
Sep 2, 2017
34
North of 60*
I've used silicone spray where the hood gasket contacts on closure to avoid it freezing to that surface.
