Hydraulic fluid getting into crankcase and coming out the dipstick hole. Replaced oem hydraulic pump with aftermarket and it's doing same thing. I am not a mechanic but read that the only way that hydraulic fluid could get into the crankcase was if the seal in the pump was bad. If this is correct, then it makes me think that it's under too much pressure or the oem pump was not rated at high enough pressure. So my questions are if it is correct that the only way hydraulic fluid can get into the crankcase is through a bad seal in the hydraulic pump? If so, is there something that is causing too much pressure to build? How would I go about fixing the problem myself without losing another pump? I am willing to buy an oem pump but want to make sure I'm not missing something first. Tractor has loader that ties in to where a block is located for the 3pt hitch. Thanks
