Anybody used one of these Hydraulic Multipliers?
mcfarmall
Kubota M5660SUHD, Farmall C
Sep 11, 2013
1,437
1,732
Kalamazoo, MI
Good Works Tractors has a couple of informative videos on the stuff from Summit Hydraulics. GWT also has a video of a pimped out Grand L 6060 with a 6 hole multiplier, third function, top-n-tilt, hydraulic SSQA lock, etc..
Repair
2017 L2501 - 2020 L2501
Apr 17, 2017
152
24
Lebanon, TN
I already have a third function for the grapple and hydraulic auger on my L2501 but I'm building a powered quick release so I need a second hydraulic function up front.
I called and talked to Summit Hydraulics, very helpful and I plan to use them.
3,933
2,585
I don't have experience with that vendor model but two way solenoid valves work fine to give you extra functions as long as you don't need to use them simultaneously.
freewheel3
Mar 9, 2013
333
34
Alberta
Yeah I seen that. Someone must have had a buddy that worked at a hydraulics shop lol. I really liked those Faster manifold type connectors, those are slick.
5,257
1,047
I use one of these much less expensive selector valves on my snow blower. $164.
selector valve
There are many similar models being offered in different places. Suggest you pay attention to the type of port. The one in the link has SAE but some are BSPP and sometimes hard to find.
gas man
b7100hst
May 25, 2019
cny
put one on the fil's tractor so he could run his round baler, plug n play simple, no hoses required and works great. his will do set a, set b, or both at the same time. dave_eng that is the valve i used to run my grapple on my b7100
