brake lights
Brankor
2018 - L4060
Nov 26, 2020
22
Sudbury Ontario
I have a 2017 L4060 and just noticed i dont have brake lights ---- Its a double element bulb but only running lights are working - Is that normal ?
Roadworthy
L2501 HST
Aug 17, 2019
1,647
530
Benton City, WA
Start by making sure both elements are good. Sometimes one element can burn out and leave the other functional. If the elements are good you need to see of you're getting power to the socket.
Brankor
2018 - L4060
Nov 26, 2020
22
Sudbury Ontario
Thanks -- I just purchase the tractor --- I don't even know if there is supposed to have brake lights -- Both bulbs are good (both element and have voltage on both) ---- Hada quick look - I don't see a brake switch at the pedal
Is there supposed to have brake lights?
aaluck
Oct 9, 2019
1,007
844
Snowdoun, AL
I do not believe they do, or at least mine doesn't -- L4400. My manual makes no mention of brake lights. Has a section on the hazard lights and turn signals, only.
3,082
I dont think they have brake lights - those are flashers? Pull the bulb - do an OHMs test on them and a voltage test on the socket.
Looking for 12+ volts DC in socket (with flasher switch on) and 0 ohms on bulb)
5,255
1,059
North American destined tractors do not come with brake lights. You may have a7 pin trailer connector but there will be no power on the brake light pin. WSM wiring diagrams sometimes show brake lights but this is because in other markets they are required
Slow Moving vehicle signs are supposed to be all you need :)
