jk welcome and we work on anything orange even green up here. I once ask that same question to the Southeast Regional Service Manager for Kubota in Swanee, GA ( Mr. Brown ) his answer way dumb founding to me
He didn't really know from his answer. Since then, I have stripped one down to find an IC circuit full of Triacs, Capacitors, resistors and an big Transistor acting as a relay that sends out voltage to your Starter solenoid terminal. This circuit demands only a controlled current that is 100 times smaller than that needed by typical isolated solid state relays. It is ideal for battery-powered systems. Using a combination of a high current TRIAC and a very sensitive low current SCR, the circuit can control about 600 watts of power to load while providing full isolation and transient protection. Go figure Ohm Law, 50 amps is more than your raw battery current output. Hence, small current drawing micro switches are just dandy for a safety seat switch, PTO switch and brake switch that must be in their designed functionality ( you know N/O, N/C position switches) and reporting ( conducting current ) into the IC Circuit ( your Black Combination Box ) for satisfying all conditions for a safe start up. This was a $110.00 experiment that my local Dealer "sucked" up from me for a brand new one 'since it was defective.'
jk I don't know you from Adam
but I'm telling you straight, you either buy one from Kubota or use this attached relay hoping your current combinaton box is not totally grounded and blowing your glow plug relay circuit to get Battery voltage to your starter solenoid or I will send you a one way shipping freight permit to send me your T1600H I love those little tractors!
Also look at the attachments for a push button remote switch you can use to start that little bugger hooked to your solenoid terminal and the starter (BAT+) terminal for a emergency start,
just have the key in the on position, not start position so the Alternator will charge the battery while running.
Good luck and let us know if box is good and your switch(s) are bad or wiring grounded, because anyone of them out of functionality will cause the Combo to be DOA and not complete the circuit for a safe start.
Well jk my Hella Relay diagram won't upload so just get a Hella 12V 4RD 960 388-22 relay from an aftermarket auto store and use the diagram with the relay to wire around the combination box for a key start or like I said ship me your tractor
