Torch, those are two great sites for both info and parts. I've used them both many times. It's amazing how many new old stock parts that are classified as "consumables" are still available for most all older outboards. And an internet search will even turn up a lot of new repro parts for many that may be the same or even better than the parts they replace.Collecting outboards is a disease. Like most diseases, there are support groups. In the US check out https://www.aomci.org/ and in Canada there's http://www.mlaoc.ca/
A great source for OEM paint colours, reproduction decals, medallions, wiring harnesses, etc. is http://nymarine.ca/ (mostly Johnson/Evinrude/Mercury, but some others as well).
Very NICE! Nothing like cruising around the lake in a vintage boat/motor combo, either. I bet those twin outboards in sync would sound like a P-38 Lightning, or in your case maybe a Bristol Beaufighter flying a mission around the lake! And our old boats draw just as much attention at the ramps as the cookie cutter new boats. I want a ride!!!I have been known to prowl a couple of local scrap dealers seeking old outboards for parts or restoration. One day, many years ago, I found a 16' runabout that had been stripped of all but the aluminium hull. The paint was rough, but it looked straight and tight, so I bought it and dragged it home, planning to hang a 22 Scott Atwater on the transom.
Which is when I discovered the transom was for a 20" long-shaft and the Scott was a 15" short-shaft. I had a long shaft 25 parts motor, so I slid the 22 sideways to make room and tried the 25 for size. I discovered two things: yes, the long-shaft motor was a perfect fit and dang, that thing looked real good with two motors hanging off the stern! All of a sudden the 25 was no longer designated as a parts motor, but rather as a candidate for resurrection.
It took 2 years to find the parts needed to assemble another long-shaft motor. The boat itself is also a collection of parts -- bits and pieces from various flea markets and swap meets. Some people have rat rods or rat bikes -- I have a rat boat. Only 50 hp total, but one heck of a hole shot, and it has the coolest sound when you get the two engines spinning at the same rpm.
Can't seem to put my finger on a good picture, so this grainy shot will have to do for now:
Now that is COOL! And it looks like the pilot and her co-pilot have everything under control, too!I have been known to prowl a couple of local scrap dealers seeking old outboards for parts or restoration. One day, many years ago, I found a 16' runabout that had been stripped of all but the aluminium hull. The paint was rough, but it looked straight and tight, so I bought it and dragged it home, planning to hang a 22 Scott Atwater on the transom.
Here's a shot that shows the bank of levers and rare Scott tachometers. And yes, that's a siren on the bow -- left over from a prior fire truck restoration. It's a rat boat -- anything goes! <lol>
Wow! Torch, that is one fine looking craft you have! Exquisite! I bet you draw a crowd at the ramps when out for a cruise. From one extreme to the other. And both just as nice and just as fun in their own way, too. What make is this boat? Fantastic restoration!If God wanted us to have fiberglass boats, he would have made fiberglass trees. ;-)
Nothing like a lovely wood boat. Some careful restoration and that will be gorgeous.
Mine was a bit of a wreck when I aquired it. It was a great father-son project 20 odd years ago and still brings us a lot of pleasure.
I noticed the "port steering" right away but figured the photo had just been flipped somehow. I wasn't aware of the different shaped ribs pertaining to different builders. Interesting! Whoever did build that boat sure done well with their lofting and coming up with those lines. She's a beauty. Maybe he was a true Englishman and wanted the steering on the proper side. LOL.The make is a bit of a mystery. No makers marks, serial number, plates or even registration numbers were visible anywhere when I got it. The steering is on the port side and the ribs are squared. Squared ribs suggests Lakefield, but they never made a port side steer model. The hull shape is somewhat reminiscent of a Peterborough, but they used rounded ribs. It has a large, thick, carved mahogany dash that just doesn't seem to fit any of the known local manufacturers. Best guess is it was a personal boat made by someone who worked in the industry, possibly during a winter lay-off. Probably 50's vintage.
Restoration work included all new decking, new floor, some seat supports, a few ribs and part of the transom. Yours looks in better shape than mine was. There's been some maintenance over the years too, of course.
The motor is a 1959 Evindrude Lark -- the Golden Jubilee edition. So my 50 year anniversary motor is now over 60 years old. It didn't come with the boat, but I feel it really suits the boat.
We think alike: I have a Fein oscillating tool and am considering modifying one of the blades to accept narrow strips of sandpaper. that may be just the ticket to get between the ribs in those narrow spots.Dremel used to make their "Contour Sander", a tiny little vibrating sander with a wide array of shapes for sanding both flats and curves in really tight spaces like that.
They've discontinued that, but now offer the MM730 contour accessory for an oscillating tool (https://us.dremel.com/en_US/products/-/show-product/accessories/mm730-contour-sander-accessory). It only comes with a few of the shapes, but looks like it uses the same sanding tubes and will fit in those spaces.
That is a lot of fuel tanks. Better use stabilizer, because it'll take you a while to use it all!
