TheKubotaKing
Kubota BX2380, with standard front loader, and LandPride rear blade ( 60 inch )
Good morning everyone,
first - I did check the official manual, and there is absolutely zero info on how / when you can engage the
4WD option. The manual is actually very sparse in regards to the info on 4WD drive, there's no alert saying not to use it on pavement etc....
That said, yesterday I tried to get my BX2380 into 4WD, and the little lever would not go. I remembered from a YouTube video you can press on the gas pedal and this can help it go into that 4WD drive mode ( by the way, the tractor was OFF while I was doing this ) I pressed the gas pedal, and bingo, it slid into that 4WD mode, or so I thought.
I started the tractor and drove it out onto the gravel driveway, and it didn't feel different. So I put the front loader bucket down on the ground, curled it, and got the front wheels to lift slightly and then gave it a bit of gas by pressing on the pedal, and the front wheels did not turn at all. So I have a feeling it didn't go 100% into that mode with the little lever.....
I guess my real question is ..... how do YOU engage your 4WD mode ? ... do you do it while the tractor is NOT moving ? or is it OK to do this while the tractor is moving very slowly forward ? I can't find any good info on this anywhere. Thanks for your thoughts on this !
