This will be our second winter at our current house with a pretty long drive made of asphalt millings. Last year I added skid shoes to the blade to keep it up off the drive. However when setting the rear blade at an angle the skid shoes take that same angle as well and dug in substantially into the driveway. I also used a small snowblower on our concrete pad as to not scrape up the concrete with the rear blade and shoes. This year I added a horse mat strip from TSC as many have used to keep from scraping up the pad. I am curious if anyone has suggestions on possibly a wheel set up similar to what is used on landscape rakes to keep it just above the grade. I am not great at fabrication, welding, etc. so something that could be attached at the bolts for the blade would be great. I may just have to float it manually as I go, which isn't the end of the world, but I wanted to see if anyone else had some other ideas.
Hopefully that all makes sense. I attached some pictures of the driveway and blade. Our turn around is at a fairly steep grade on the one side so that makes moving snow a little difficult while turning, but not impossible.
